Einleitung
This guide will show you, how to safely remove Optical Disk Drive from your Fujitsu Esprimo Mobile notebook, model V6555. REMEMBER! You're doing it at your own risk! However, it's easy. Just take your time, keep thing organized.
Was du brauchst
1. Turn your notebook over.
2. For safety reasons, remove your battery. Turn switch on right inwards. Do the same with the one on the left. Hold it, then remove battery pack.
Remove screw holding ODD in place.
Gently remove your ODD. Just use your fingertips, it should slide out very easy.
