Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
You can install a new hard drive in your computer.
  1. Locate the two clips on the bottom of the computer that support the battery.
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Using your fingers,  push the clips inward and then upward.
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Remove the two screws securing the hard drive access cover.
    • Remove the two screws securing the hard drive access cover.
    • Screws not shown in picture.
  4. Remove hard drive access cover. Remove hard drive access cover.
    • Remove hard drive access cover.
  5. Grasp hard drive sleeve tab and pull out. Grasp hard drive sleeve tab and pull out.
    • Grasp hard drive sleeve tab and pull out.
  6. Remove hard drive from plastic sleeve. Remove hard drive from plastic sleeve. Remove hard drive from plastic sleeve.
    • Remove hard drive from plastic sleeve.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Neil Daniels
1.369 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 5-18, Amido Winter 2011 Mitglied von Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Mitglieder
22 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 56
Insgesamt: 8,732
