Einleitung
The hinge cover has the computer power button, wireless switch, and volume toggle.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Locate the two clips on the bottom of the computer that support the battery.
Using your fingers, push the clips inward and then upward.
Lift the battery out of the computer.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Lay the computer flat on a stable surface with the monitor pointing away from you.
Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
