Zum Hauptinhalt wechseln
Fujitsu Lifebook A6110 RAM Replacement
Was du brauchst
  1. Fujitsu Lifebook A6110 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Fujitsu Lifebook A6110 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujitsu Lifebook A6110 RAM Replacement: Schritt 2, Bild 1 von 1
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
  3. Fujitsu Lifebook A6110 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Fujitsu Lifebook A6110 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
    • Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
  4. Fujitsu Lifebook A6110 RAM Replacement: Schritt 4, Bild 1 von 3 Fujitsu Lifebook A6110 RAM Replacement: Schritt 4, Bild 2 von 3 Fujitsu Lifebook A6110 RAM Replacement: Schritt 4, Bild 3 von 3
    • Slide the cover towards the screw, and then lift the cover upwards.
  5. Fujitsu Lifebook A6110 RAM Replacement: Schritt 5, Bild 1 von 2 Fujitsu Lifebook A6110 RAM Replacement: Schritt 5, Bild 2 von 2
    • There are two RAM cards in this compartment. They look like small green plastic chips with black squares on each of them. These cards are beneath a thin plastic sheet that must be pulled out of the way.
    • Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
    • If done correctly, the RAM card will eject at a 45 degree angle.
  6. Fujitsu Lifebook A6110 RAM Replacement: Schritt 6, Bild 1 von 1
    • Pull the RAM card out while maintaining the 45 degree angle it ejected at.
    • When reassembling, the gold pins on the RAM card must match the corresponding pins found on the motherboard.
    • If you choose to replace the other RAM card, repeat the process in Step 5.
Abschluss
Cody Moniz
416 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 887
