Einleitung
If the laptop tends to overheat then the laptop fan may need to be replaced, this guide will show you how to remove the fan from the Fujitsu Lifebook S6120.
Was du brauchst
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
Use the tweezers to disconnect the ribbon cable from the motherboard.
With the tweezers detach hinge cover cables from the motherboard.
Remove hinge cover.
Use tweezers to remove the wires from the Adapter.
Use a Philips head #0 to remove the 5mm screws.
Use a Philips head #00 to remove the 4mm screws.
Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
Remove the ribbon from the motherboard with a pair of tweezers.
Remove the 3.5mm screws with a Philips head #0.
Remove the metal bracket and other pieces that rely on it for structure.
Using a Philips head size #0 remove the 3mm screw on the back of the motherboard.
Using tweezers detach the cable from the motherboard.
