Einleitung
If the keyboard is not responding or inputs incorrectly then your keyboard may need to be replaced, this guide will show you how to remove the keyboard from the Fujitsu Lifebook S6120.
Was du brauchst
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
Use the tweezers to disconnect the ribbon cable from the motherboard.
With the tweezers detach hinge cover cables from the motherboard.
Remove hinge cover.
Eine weitere Person hat diese Anleitung absolviert.
