Einleitung
If your computer is completely unresponsive and the motherboard needs to be replaced or repaired, this guide will show you how to remove the motherboard from the Fujitsu Lifebook S6120.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Push the two tabs in towards the laptop.
Lift the battery up and out from the frame of the laptop.
Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
With the tweezers detach hinge cover cables from the motherboard.
Remove hinge cover.
Use a Philips head #0 to remove the 5mm screws.
Use a Philips head #00 to remove the 4mm screws.
Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
Remove the 3.5mm screws with a Philips head #0.
Remove the metal bracket and other pieces that rely on it for structure.
