Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If the picture on the screen of the laptop is distorted or is blacked out then the screen may need to be replaced, this guide will show you how to remove the screen from the Fujitsu Lifebook S6120.
  1. To prevent injury, make sure the laptop is unplugged and turned off before removing the battery. Push the two tabs in towards the laptop. Lift the battery up and out from the frame of the laptop.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer. Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Lift the hinge cover.
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Use the tweezers to disconnect the ribbon cable from the motherboard. Use the tweezers to disconnect the ribbon cable from the motherboard. Use the tweezers to disconnect the ribbon cable from the motherboard.
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. With the tweezers detach hinge cover cables from the motherboard. Remove hinge cover. Remove hinge cover.
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Lift keyboard enough to show the ribbon cable. The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage. The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Use a plastic opening tool to release the ribbon cable from the motherboard. Use a plastic opening tool to release the ribbon cable from the motherboard. Use a plastic opening tool to release the ribbon cable from the motherboard.
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Push the secure clips outward. The Adapter should pop up. The Adapter should pop up.
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Use tweezers to remove the wires from the Adapter. Use tweezers to remove the wires from the Adapter. Use tweezers to remove the wires from the Adapter.
    • Use tweezers to remove the wires from the Adapter.
  10. Take out the Adapter and carefully pull the wires out from the metal casing. Take out the Adapter and carefully pull the wires out from the metal casing.
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Remove the 4mm screws from the laptop with a Philips head #0 Remove the 4.5mm screws on the back of the laptop with a Philips #0
    • Remove the 4mm screws from the laptop with a Philips head #0
    • Remove the 4.5mm screws on the back of the laptop with a Philips #0
  12. Use a plastic opening tool to lift up both sides of the white tab. Use a plastic opening tool to lift up both sides of the white tab. Use a plastic opening tool to lift up both sides of the white tab.
    • Use a plastic opening tool to lift up both sides of the white tab.
  13. Use tweezers to grab onto the lever to remove the chip from the motherboard. Use tweezers to grab onto the lever to remove the chip from the motherboard.
    • Use tweezers to grab onto the lever to remove the chip from the motherboard.
  14. Lift the screen up vertically
    • Lift the screen up vertically
  15. Remove rubber tabs with hands Use a Philips head #0 to remove the 3mm screws Use a Philips head #0 to remove the 3mm screws
    • Remove rubber tabs with hands
    • Use a Philips head #0 to remove the 3mm screws
  16. Use the metal spudger to pry up the edge of the plastic casing up. Remove the plastic frame from the screen.
    • Use the metal spudger to pry up the edge of the plastic casing up.
    • Remove the plastic frame from the screen.
  17. Remove the 3mm screws with a Philips head #00
    • Remove the 3mm screws with a Philips head #00
  18. Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
    • Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
  19. Lift the screen from the frame Lift the screen from the frame
    • Lift the screen from the frame
  20. Remove the ribbon from the back of the screen Remove the ribbon from the back of the screen
    • Remove the ribbon from the back of the screen
  21. Use a pair of tweezers remove the white connector Use a pair of tweezers remove the white connector Use a pair of tweezers remove the white connector
    • Use a pair of tweezers remove the white connector
Abschluss
Jessi Gallant
899 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S5-G5, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G5, Peak Spring 2018
UMASSD-PEAK-S18S5G5
3 Mitglieder
18 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 4
Letzten 30 Tage: 17
Insgesamt: 305
