Einleitung
If you need to replace the camera this guide will provide step-by-step instructions on how to disassemble and replace your camera.
Was du brauchst
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Insert the plastic opening tool along the seam of the back case.
Gently slide the plastic opening tool along the entire seam popping the clips free.
Carefully lift the back case and remove the smartcard ribbon from the motherboard.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
