Zum Hauptinhalt wechseln
Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement
Was du brauchst
  1. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Inner Back Shield: Schritt 4, Bild 1 von 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 6, Bild 1 von 1
  7. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 7, Bild 1 von 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Battery: Schritt 8, Bild 1 von 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 9, Bild 1 von 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 10, Bild 1 von 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Headphone Jack: Schritt 12, Bild 1 von 1
    • Remove the two 0.2 mm screws with a PH00 Screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 13, Bild 1 von 1
    • Remove the two 0.2 mm screws with a PH00 screwdriver
  14. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 14, Bild 1 von 1
    • Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
  15. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 15, Bild 1 von 2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 15, Bild 2 von 2
    • Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
  16. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 16, Bild 1 von 2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: Schritt 16, Bild 2 von 2
    • When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
Abschluss
IUPUI, Team S1-G1, Henning Spring 2019 Mitglied von IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 446
