Einleitung
This guide allows the user to access and replace the MicroSD card of a Fujitsu Lifebook Stylistic Q584.
Was du brauchst
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Insert the plastic opening tool along the seam of the back case.
Gently slide the plastic opening tool along the entire seam popping the clips free.
Carefully lift the back case and remove the smartcard ribbon from the motherboard.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
Disconnect upper peripheral ribbons from motherboard.
Disconnect left peripheral ribbon from motherboard.
Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
Gently separate the MicroSD card from the device.
1 Kommentar zur Anleitung
I have some OS problem can the SSD be replaced..?
