Zum Hauptinhalt wechseln
Fujitsu Siemens Amilo Pro Keyboard Replacement
Was du brauchst
  1. Fujitsu Siemens Amilo Pro Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Fujitsu Siemens Amilo Pro Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Fujitsu Siemens Amilo Pro Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the one screw holding in the keyboard.
  4. Fujitsu Siemens Amilo Pro Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Pull the keyboard up towards you.
  5. Fujitsu Siemens Amilo Pro Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
try to focus the image while taking the picture so people can understand better were to touch
storm builder - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 15,527
