Was du brauchst
First, we unlock the battery so you can remove it by stretching it later.
First we unscrew the cover, after the triplet and lastly, we retrieved the RAM to do it, we just have to move the "tabs" that are to the sides and the RAM will go alone
First we unscrew the card and then go alone, we will have to disconnect it only
First, disconnect the power cord, and then unscrew the fan. Once we have taken it we can take advantage of it to open it to clean it up.
To mount it we have to do the opposite that when disassembling, you put it on and then put the screw
Put the fan in place and screw it, we also have to connect the cable to the plate
Now we place the network card in its place, download it and then screw it, finally we have to connect the cables in the corresponding order
Now we have to place RAM, we just have to put it in place diagonally and then download it.
Now we will put the hard disk, first put it in its space and we move it to connect it, then screw it and close the lid.
We just have to put the lid, screw and put the battery in the battery, a wandering, we have to put the insurance.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
irlanda hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
