Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
Use a plastic opening tool to remove the screen cover from the rest of the lid.
Remove one screw located on the left side of the phone with the pictured orientation in mind.
This will release the logic board from the back case.
Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
There is a plastic square that surrounds the camera and keeps it in place. Pry this up first making note of the orientation of the part and how there is a tab pointing in the same direction as the ribbon cable.
Once it is loosened the surround can be removed and set aside. The next step is to detach the ribbon cable.
Now turn the phone over so that you are looking at the inside LCD and the back of the camera.
Use a pry stick to disconnect the ribbon cable from the rest of the PCB board.
To disassemble your device, follow these instructions in reverse order.
