Zum Hauptinhalt wechseln
G'z One Boulder Inside Screen Cover Replacement
Was du brauchst
  1. G'z One Boulder Inside Screen Cover Replacement, Inside Screen Cover: Schritt 1, Bild 1 von 1
    • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • Make note that two of the screws closest to the hinge are longer than the other two.
  2. G'z One Boulder Inside Screen Cover Replacement: Schritt 2, Bild 1 von 2 G'z One Boulder Inside Screen Cover Replacement: Schritt 2, Bild 2 von 2
    • Remove the two side screws.
    • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  3. G'z One Boulder Inside Screen Cover Replacement: Schritt 3, Bild 1 von 2 G'z One Boulder Inside Screen Cover Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to remove the screen cover from the rest of the lid.
  4. G'z One Boulder Inside Screen Cover Replacement: Schritt 4, Bild 1 von 2 G'z One Boulder Inside Screen Cover Replacement: Schritt 4, Bild 2 von 2
    • Your phone should look like the picture to the left.
    • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
Abschluss
To disassemble your device, follow these instructions in reverse order.
Clemson, Team 13-3, Benson Spring 2013 Mitglied von Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 503
