Zum Hauptinhalt wechseln
GATEWAY ML6720 Keyboard Replacement
Was du brauchst
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Keyboard Replacement: Schritt 3, Bild 1 von 2 GATEWAY ML6720 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Keyboard Replacement: Schritt 4, Bild 1 von 2 GATEWAY ML6720 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Keyboard Replacement: Schritt 5, Bild 1 von 2 GATEWAY ML6720 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
  5. GATEWAY ML6720 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 1
    • Turn the laptop on its backside with the stickers and barcode facing you.
  6. GATEWAY ML6720 Keyboard Replacement: Schritt 7, Bild 1 von 3 GATEWAY ML6720 Keyboard Replacement: Schritt 7, Bild 2 von 3 GATEWAY ML6720 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Be careful of losing the screws because of how small they are
    • Remove the six 2.0mm Phillips screws and panels from the back of the RAM, motherboard, and laptop fan.
  7. GATEWAY ML6720 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Have your laptop remained on the backside
    • Remove the twelve identical 2.0mm Phillips Screws located around the back of the laptop using the Phillips #0 Screwdriver.
    • Remove the entire back panel of the laptop
  8. GATEWAY ML6720 Keyboard Replacement: Schritt 9, Bild 1 von 2 GATEWAY ML6720 Keyboard Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using a pair of tweezers or the tip of your screw driver, dig into the laptop cover and apply force to pop it out.
    • Do this on the left and right side of the cover
  9. GATEWAY ML6720 Keyboard Replacement: Schritt 10, Bild 1 von 2 GATEWAY ML6720 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Pull up the keyboard with your finger
Abschluss
Nathan Da Silva
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 541
