Zum Hauptinhalt wechseln
GATEWAY NE56R09u RAM Replacement
Was du brauchst
  1. GATEWAY NE56R09u RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u RAM Replacement: Schritt 2, Bild 1 von 1
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u RAM Replacement: Schritt 3, Bild 1 von 1
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Locate the casing that protects the RAM modules, wireless card, and hard drive.
  5. GATEWAY NE56R09u RAM Replacement: Schritt 5, Bild 1 von 1
    • With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
  6. GATEWAY NE56R09u RAM Replacement: Schritt 6, Bild 1 von 1
    • On each RAM module there are two silver latches holding them in place
    • Release the latches to be able to remove the RAM module.
  7. GATEWAY NE56R09u RAM Replacement: Schritt 7, Bild 1 von 1
    • Remove the RAM modules from their respected slots.
Abschluss
To reassemble your device, please follow these instructions in reverse order.
joshua depina
401 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S6-G1, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G1, Peak Spring 2019
UMASSD-PEAK-S19S6G1
2 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 234
