Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Use this guide to replace the outer case.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Find the battery compartment on the bottom of the clock radio. Using your thumb, push the compartment cover latch toward the battery. With the latch pushed in, pull the compartment cover upward to remove it..
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. Lift the battery from the compartment. Pull the battery up and gently disconnect it from the battery connector.
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio. Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. Gently pull the liquid crystal display (LCD) cover off.
    • Gently pull the liquid crystal display (LCD) cover off.
  5. Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside. Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Dominick Giguere
848 Reputation
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 214
