Zum Hauptinhalt wechseln
GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement
Was du brauchst
  1. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: Schritt 1, Bild 1 von 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: Schritt 1, Bild 2 von 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: Schritt 1, Bild 3 von 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: Schritt 2, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: Schritt 2, Bild 2 von 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: Schritt 3, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: Schritt 3, Bild 2 von 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, LCD Cover: Schritt 4, Bild 1 von 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: Schritt 5, Bild 1 von 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: Schritt 5, Bild 2 von 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 364
