Einleitung
If the lightbulb of your GE GTE18GSHHRSS refrigerator burned out, use this guide as a reference for a lightbulb replacement. If the lightbulb is not replaced, items in refrigerator may not be seen and could possible spoil.
Before using this guide, make sure that the lightbulb has not exploded, if the lightbulb has exploded, clean up the glass debris and make sure to remove any excess glass debris inside of the lightbulb socket.
It may be helpful to clear out the food from the area where you'll be working to give you a little more space for the job.
Was du brauchst
Open the refrigerator and remove all items out of the way of the lightbulb.
Use a microfiber cloth to clean around the area and to make sure there is no debris in the socket.
