Einleitung
After years of use, the fridge gasket may begin to detach from your refrigerator door. This can lead to cold air escaping, causing food to spoil. This guide will demonstrate how to remove and replace the fridge gasket on your GE GTR12BSXABS refrigerator, ensuring that your fridge continues to keep your food fresh and remains usable for as long as possible.
Was du brauchst
Gently but firmly remove the old fridge gasket from the refrigerator door.
Start at one corner and work your way around the perimeter.
Clean and dry the surface with an all-purpose cleaner and a kitchen cloth or rag to ensure the new fridge gasket sticks properly.
Take the new fridge gasket and place it along the inside edge of the door.
Begin by pressing down one corner of the gasket onto the fridge. Continue going around the fridge, gradually placing the gasket until it is securely in place and properly adhered.
To help the new fridge gasket expand back into shape, heat the new fridge gasket’s entire side surfaces with a hair dryer, which should be held about 15 cm away for about a minute and 15 seconds.
Enjoy the newfound longevity of your fridge.
