Einleitung
Use this guide to diagnose and cure an oven that glows but never heats. You will confirm gas supply, measure igniter amperage, interpret the readings, and install a universal replacement igniter. The same procedure applies to most GE-made ranges and many other brands that use a clamp-style igniter.
Was du brauchst
Schritt 1 Confirm gas supply at the cooktop
Turn a surface burner to Light and verify that it sparks and produces a steady flame.
Schritt 2 Energize the bake circuit for testing
Make sure the range power cord is plugged in so the igniter receives voltage.
Set the oven control to Bake and choose roughly 350–450 °F to activate the bake relay.
Schritt 3 Access wiring below the oven
Pull out the warming drawer and slide underneath the chassis to reach the safety valve area.
Locate the safety valve on the right side and the wire pairs that leave the valve toward each igniter.
Schritt 5 Clamp the multimeter on the bake wire
Rotate the multimeter to the 2 A ⁄ 20 A setting to read low current.
Place the amp-clamp around the white bake wire only and confirm no other conductors are inside the jaws.
Angle the meter so the display is visible while you are under the oven.
Schritt 6 Interpret bake igniter amperage
Let the igniter heat for about one minute and watch the current rise.
Normal current is 2.8–3.4 A; the safety valve will not open below this range.
Schritt 7 Compare broil igniter current
Turn the control off, move the clamp to the blue broil wire, and set Broil.
A healthy broil igniter jumps near 3.3 A then levels around 2.85 A in about a minute.
Schritt 8 Disconnect electrical power
Turn the oven controls off and unplug the range before touching any wiring.
Schritt 9 Remove the oven floor plate
Inside the cavity, loosen the two rear thumb screws with a flat-head screwdriver.
Lift the rear of the plate, slide it forward, and remove it to reveal the burner and igniter.
Schritt 10 Assess igniter condition visually
Check for heavy white oxidation or crumbling ceramics on the igniter tip.
Schritt 11 Detach burner tube and wiring
Remove the quarter-inch hex screw at the front of the burner tube.
From underneath, back out the two rear hex screws securing the tube to the chassis.
Unplug the spade connector at the safety valve and the harness connector leading to the control board.
Schritt 12 Remove the old igniter
Lift the burner tube out of the oven and place it on a stable surface.
Take out the two quarter-inch hex screws that mount the igniter to the tube and set the failed igniter aside.
Schritt 13 Install the new igniter on the tube
Align the bracket holes and secure the new igniter with the original hex screws.
Schritt 14 Splice the connector leads
Cut the original GE harness, strip each lead about 13 mm, and twist it with the leads from the new igniter.
Secure the splice with the supplied ceramic wire nut to protect it from heat.
Schritt 15 Reinstall the burner tube assembly
Guide the igniter wires through the opening while sliding the burner tube back onto the gas orifice.
Reinstall the two rear screws and the single front screw to lock the tube in place.
Schritt 16 Reconnect igniter wiring
Attach one igniter lead to the safety valve terminal and the other to the harness connector going to the control board.
Schritt 17 Confirm correct amperage with the new igniter
Plug the range back in, clamp the meter on the white bake wire, and select Bake 350 °F.
A good igniter spikes to about 3.5 A and settles near 3 A within seconds, proving the repair.
Schritt 18 Reassemble the oven cavity
Slide the floor plate into the front channel, lower the rear edge, and tighten the two thumb screws.
Reinsert the warming drawer and verify smooth movement.
Schritt 19 Run a final functional test
Light a surface burner and run a short bake cycle to confirm reliable ignition and no gas odor.
With amperage back in the 3 A range, the safety valve now opens quickly and the oven heats normally. Keep the clamp-meter method in mind: when an igniter glows but does not reach 2.8 A, replacement is the reliable fix.
