Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will give step by step instructions on how to replace the light bulb in an oven, specifically for the GE TrueTemp, however these steps can be used for various other models. This repair only requires a new light bulb and a dry cloth or gloves to protect the bulb from coming into contact with anything that could damage it, including natural oils on the hand. This repair should be fairly quick to complete, as it should take no more than 3-5 minutes. Note that other oven models may have slight variations in the location of the light bulb.
Werkzeuge
Ersatzteile
  1. Unplug the power cord from the wall outlet for safety purposes.
    • Unplug the power cord from the wall outlet for safety purposes.
  2. Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. Locate the metal strap holding the glass cover over the bulb.
    • Locate the metal strap holding the glass cover over the bulb.
  4. Slide the strap to the side to free the glass casing.
    • Slide the strap to the side to free the glass casing.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  7. Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  8. Screw in new light bulb in the clock wise direction. Screw in new light bulb in the clock wise direction.
    • Screw in new light bulb in the clock wise direction.
  9. Replace the glass cover over the bulb, but be sure to hold on to it tightly.
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  10. Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  11. Plug the oven power cord back into power source.
    • Plug the oven power cord back into power source.
  12. Press the button for oven light to come on.
    • Press the button for oven light to come on.
  13. View light to ensure the replacement was successful.
    • View light to ensure the replacement was successful.
Ziellinie
Samantha Connell
214 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
15 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 33
Letzten 30 Tage: 199
Insgesamt: 1,357
