Zum Hauptinhalt wechseln
GE TrueTemp Oven Light Bulb Replacement
Was du brauchst
  1. GE TrueTemp Oven Light Bulb Replacement, Light Bulb: Schritt 1, Bild 1 von 1
    • Unplug the power cord from the wall outlet for safety purposes.
  2. GE TrueTemp Oven Light Bulb Replacement: Schritt 2, Bild 1 von 1
    • Open the oven door and locate the oven light placement (located on the back wall, in upper left corner for this specific model.)
  3. GE TrueTemp Oven Light Bulb Replacement: Schritt 3, Bild 1 von 1
    • Locate the metal strap holding the glass cover over the bulb.
  4. GE TrueTemp Oven Light Bulb Replacement: Schritt 4, Bild 1 von 1
    • Slide the strap to the side to free the glass casing.
  5. GE TrueTemp Oven Light Bulb Replacement: Schritt 5, Bild 1 von 1
    • View the light bulb without the glass case and ensure there is nothing else securing it to the oven.
    • Check to make sure there is no debris around the bulb and that the light bulb is ready to be removed.
  6. GE TrueTemp Oven Light Bulb Replacement: Schritt 6, Bild 1 von 1
    • Using a dry cloth or gloves, unscrew the light bulb by turning it in a counter clockwise motion.
  7. GE TrueTemp Oven Light Bulb Replacement: Schritt 7, Bild 1 von 2 GE TrueTemp Oven Light Bulb Replacement: Schritt 7, Bild 2 von 2
    • Screw in new light bulb in the clock wise direction.
  8. GE TrueTemp Oven Light Bulb Replacement: Schritt 8, Bild 1 von 1
    • Replace the glass cover over the bulb, but be sure to hold on to it tightly.
  9. GE TrueTemp Oven Light Bulb Replacement: Schritt 9, Bild 1 von 1
    • Secure the glass case to the oven with the metal strap by sliding it back over case until it fits tightly.
  10. GE TrueTemp Oven Light Bulb Replacement: Schritt 10, Bild 1 von 1
    • Plug the oven power cord back into power source.
  11. GE TrueTemp Oven Light Bulb Replacement: Schritt 11, Bild 1 von 1
    • Press the button for oven light to come on.
  12. GE TrueTemp Oven Light Bulb Replacement: Schritt 12, Bild 1 von 1
    • View light to ensure the replacement was successful.
Ziellinie
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
31 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 47
Letzte 30 Tage: 186
Insgesamt: 19,945
