Zum Hauptinhalt wechseln
GK61 Keyboard Keycap/Switch Replacement
Was du brauchst
  1. GK61 Keyboard Keycap/Switch Replacement, Keycap/Switches: Schritt 1, Bild 1 von 1
    • Unplug the keyboard.
    • When the keyboard lights are off, it indicates that the keyboard is turned off.
  2. GK61 Keyboard Keycap/Switch Replacement: Schritt 2, Bild 1 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 2, Bild 2 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 2, Bild 3 von 3
    • Use a keycap puller to remove the top and bottom of the keycaps from the keyboard.
    • When pulling the keycap, make sure to apply pressure until you hear a click sound from the keycap.
    • Remember when using a keycap puller, place it on a key in a vertical position.
  3. GK61 Keyboard Keycap/Switch Replacement: Schritt 3, Bild 1 von 1
    • After removing all the keycaps, put it in a bowl.
    • You can either use alcohol wipes or water to clean your keycaps.
  4. GK61 Keyboard Keycap/Switch Replacement: Schritt 4, Bild 1 von 1
    • Dry the keycaps on a rag or paper towel.
    • Remember to let your keycaps dry for about 5-10 minutes after cleaning.
  5. GK61 Keyboard Keycap/Switch Replacement: Schritt 5, Bild 1 von 1
    • Using a hand held vacuum cleaner remove any excess dust, hair, and oils.
    • Tilting your keyboard will also help for a deeper clean
    • If you cannot locate a hand held vacuum cleaner, a compressed air duster will also work.
  6. GK61 Keyboard Keycap/Switch Replacement: Schritt 6, Bild 1 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 6, Bild 2 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 6, Bild 3 von 3
    • Using a Q-Tip with rubbing alcohol, gently clean and rub the crevices around the plate of the keyboard.
    • Make sure not to pour rubbing alcohol onto your keyboard. Doing so may cause severe damage to the keyboard.
  7. GK61 Keyboard Keycap/Switch Replacement: Schritt 7, Bild 1 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 7, Bild 2 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 7, Bild 3 von 3
    • Using a switch puller, pull the keyboard switch from the top and bottom of the switch.
    • Remember to always pull straight up to fully remove the switch.
  8. GK61 Keyboard Keycap/Switch Replacement: Schritt 8, Bild 1 von 2 GK61 Keyboard Keycap/Switch Replacement: Schritt 8, Bild 2 von 2
    • Grab a replacement switch to replace the broken switch.
    • Push the switch straight down into the socket of the switch.
    • To avoid any damages, make sure to always push straight down and not in any other direction.
  9. GK61 Keyboard Keycap/Switch Replacement: Schritt 9, Bild 1 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 9, Bild 2 von 3 GK61 Keyboard Keycap/Switch Replacement: Schritt 9, Bild 3 von 3
    • After drying the keycaps, put the keycaps back into their sockets.
    • Align the keycap with the socket of the switch and push straight down with a bit of pressure.
    • When pushing straight down, you will hear a click sound that will indicate that the keycap has been placed.
Abschluss
Alexander Truong
169 Reputation
1 Anleitung geschrieben
York University, Team S1-G28, O'Regan Summer 2021 Mitglied von York University, Team S1-G28, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G28
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 39
Insgesamt: 1,536
