Einleitung
This purpose of this guide is to provide clear instructions for replacing the plastic housing for a GM Key Fob. Replacing just the housing, instead of the entire Fob, can save the individual a significant amount of money in addition to reducing environmental and electrical waste.
Was du brauchst
Pry apart the key ring to remove it from the old housing.
Once you have removed the key ring, use it to open the housing by wedging it into the groove, as pictured.
After Opening the new Key Fob package, select the correct housing as more than one model is included.
To reassemble your device, simply follow these disassembly instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
