Zum Hauptinhalt wechseln
GMMK-BRN Keyboard Switch Replacement
Was du brauchst
  1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: Schritt 1, Bild 1 von 2 GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: Schritt 1, Bild 2 von 2
    • Unplug the keyboard from your device.
    • Place the keyboard on a clean workspace, along with the tools required.
  2. GMMK-BRN Keyboard Switch Replacement: Schritt 2, Bild 1 von 3 GMMK-BRN Keyboard Switch Replacement: Schritt 2, Bild 2 von 3 GMMK-BRN Keyboard Switch Replacement: Schritt 2, Bild 3 von 3
    • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
    • It is possible to damage the keycap if not pulled directly upwards.
  3. GMMK-BRN Keyboard Switch Replacement: Schritt 3, Bild 1 von 2 GMMK-BRN Keyboard Switch Replacement: Schritt 3, Bild 2 von 2
    • Use the switch remover to push the tabs in on the opposite sides of the switch.
    • Firmly pull the switch upwards.
    • If the switch is pulled at an angle, there is a risk to damaging the switch.
    • The switch may not come out easily, so more force may be required.
  4. GMMK-BRN Keyboard Switch Replacement: Schritt 4, Bild 1 von 3 GMMK-BRN Keyboard Switch Replacement: Schritt 4, Bild 2 von 3 GMMK-BRN Keyboard Switch Replacement: Schritt 4, Bild 3 von 3
    • Align the pins on the keycap with the ones inside the keyboard.
    • Insert the switch, and press down firmly until a click is heard.
  5. GMMK-BRN Keyboard Switch Replacement: Schritt 5, Bild 1 von 3 GMMK-BRN Keyboard Switch Replacement: Schritt 5, Bild 2 von 3 GMMK-BRN Keyboard Switch Replacement: Schritt 5, Bild 3 von 3
    • Align the cross of the keycap with the cross of the switch.
    • Push the keycap down firmly to reattach.
  6. GMMK-BRN Keyboard Switch Replacement: Schritt 6, Bild 1 von 2 GMMK-BRN Keyboard Switch Replacement: Schritt 6, Bild 2 von 2
    • Plug the keyboard back into your device.
    • Turn you device on and do a test to see if the new switch works.
Abschluss
Kyle Lieu Dang
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 624
