Zum Hauptinhalt wechseln
GPD Win Battery Replacement
Was du brauchst
  1. GPD Win Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down your GPD Win.
  2. GPD Win Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove SD card and duct cover.
  3. GPD Win Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the six PH #00 screws on the back of the GPD.
  4. GPD Win Battery Replacement: Schritt 4, Bild 1 von 3 GPD Win Battery Replacement: Schritt 4, Bild 2 von 3 GPD Win Battery Replacement: Schritt 4, Bild 3 von 3
    • Carefully insert the pry tool between the keyboard and case.
    • Move the tool around the edge until every clip is released.
    • Carefully lift the back half of the case.
    • You'll see a small ribbon connector on the right. Use your pry tool to remove it by lifting up.
    • On the right, you'll see another white connector going to the battery. Use the pry tool and pull back on the connector to release it.
  5. GPD Win Battery Replacement: Schritt 5, Bild 1 von 3 GPD Win Battery Replacement: Schritt 5, Bild 2 von 3 GPD Win Battery Replacement: Schritt 5, Bild 3 von 3
    • Separate the two halves of the device.
    • Use the pry tool and slowly and carefully separate the adhesive from the back of the case.
    • Remove old battery.
  6. GPD Win Battery Replacement: Schritt 6, Bild 1 von 2 GPD Win Battery Replacement: Schritt 6, Bild 2 von 2
    • Use two to three strips of the double sided tape and apply it to the back of the battery.
    • Line up the battery with the lines on the case and the connector on the right.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 7
Letzten 7 Tage: 35
Letzten 30 Tage: 205
Insgesamt: 3,267
