Zum Hauptinhalt wechseln
Einleitung
GPU Replacement is something you do once your old GPU is obsolete, so we’re here to show you how to replace you old one with a new one, no special skills required.
This is an easy step by step guide on how to replace a Graphics Processing Unit (GPU) that is inside a Deepcool Kendomen, on an MSI Z97 Gaming 5 Motherboard.
  • Before using this guide please ensure that you have your new GPU unpacked and ready to install.
  • Please turn off your Desktop before starting.
Here is the user guide released by Deepcool for the Kendomen.
  1. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard, Graphics Processing Unit (GPU): Schritt 1, Bild 1 von 2 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard, Graphics Processing Unit (GPU): Schritt 1, Bild 2 von 2
    • Make sure your Computer is off before starting!
    • Unplug your desktop from the wall outlet.
    • Turn your desktop so you have access to the back of the device.
  2. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 2, Bild 1 von 2 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 2, Bild 2 von 2
    • Switch off the PSU to prevent power flow.
    • Unplug your desktop to prevent any power flow.
  3. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 3, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 3, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 3, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the two 15 mm screws on the glass panel side and remove the panel.
  4. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 4, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 4, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 4, Bild 3 von 3
    • Gently remove the glass panel, by sliding it towards yourself.
    • The panel contains glass so be gentle with it!
    • The GPU is highlighted.
    • Using the Phillips #0 screwdriver, remove the three 14 mm screws connecting the GPU to the motherboard.
    • Unplug the power cable on the GPU.
  5. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 5, Bild 1 von 1
    • Unplug the GPU from the power supply, since we need to remove anything connected to it.
  6. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 6, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 6, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 6, Bild 3 von 3
    • Use the Phillips #0 to remove the three 14mm Phillips screws from the GPU and motherboard so we can remove the GPU later.
  7. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 7, Bild 1 von 2 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 7, Bild 2 von 2
    • Push down on the tab to unlock the GPU.
    • The tab unlocks easily, so don't apply too much force.
  8. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 8, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 8, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 8, Bild 3 von 3
    • Gently pull the old GPU out.
    • The PCI-E slot is now empty for a new GPU.
  9. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 9, Bild 1 von 1
    • Line up the GPU with the PCI-E Slot.
    • Push the GPU in, make sure to line it up properly with the PCI-E and the rear end of the case.
    • The tab will click in when you push the GPU in.
  10. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 10, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 10, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 10, Bild 3 von 3
    • Screw the three 14 mm Phillips screws back in using the Phillips #0 screwdriver.
  11. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 11, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 11, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 11, Bild 3 von 3
    • Reconnect the 8-Pin Male Cable from the PSU into the GPU to power it when we turn it on.
  12. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 12, Bild 1 von 1
    • Slide the glass panel back in.
  13. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 13, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 13, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 13, Bild 3 von 3
    • Using the Phillips #0 screwdriver, screw in the two 15 mm screws back into the case to lock the panel into place.
  14. GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 14, Bild 1 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 14, Bild 2 von 3 GPU Replacement On a Deepcool Kendomen and MSI Z97 Gaming 5 Motherboard: Schritt 14, Bild 3 von 3
    • Connect the female part of the power cord into the PSU.
    • Turn on the switch and power on your PC.
Abschluss
The brand or generation of GPU you intend to install does not matter, as long as it can fit the PCI-E slot located on your motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Faiz Khan
265 Reputation
1 Anleitung geschrieben
York University, Team S2-G11, O'Regan Winter 2021 Mitglied von York University, Team S2-G11, O'Regan Winter 2021
YORK-O'REGAN-W21S2G11
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 29
Letzten 30 Tage: 140
Insgesamt: 1,356
