Zum Hauptinhalt wechseln
GPU Replacement
Was du brauchst
  1. GPU Replacement, Graphics Processing Unit: Schritt 1, Bild 1 von 1
    • Establish a clean work space.
  2. GPU Replacement: Schritt 2, Bild 1 von 3 GPU Replacement: Schritt 2, Bild 2 von 3 GPU Replacement: Schritt 2, Bild 3 von 3
    • Turn the desktop's power supply off.
    • Unplug the desktop from all power sources.
  3. GPU Replacement: Schritt 3, Bild 1 von 2 GPU Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws on the side of the case.
    • Screw types may vary by desktop case.
    • These screws hold the side panel, which promotes airflow inside the desktop. Do not misplace them.
  4. GPU Replacement: Schritt 4, Bild 1 von 2 GPU Replacement: Schritt 4, Bild 2 von 2
    • Gently remove the side panel by pulling it away from the case.
  5. GPU Replacement: Schritt 5, Bild 1 von 1
    • Place the desktop horizontally, so the motherboard is facing up.
  6. GPU Replacement: Schritt 6, Bild 1 von 3 GPU Replacement: Schritt 6, Bild 2 von 3 GPU Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the 8-pin PCI-E cable from the GPU.
  7. GPU Replacement: Schritt 7, Bild 1 von 2 GPU Replacement: Schritt 7, Bild 2 von 2
    • Remove the UTS 6-32 screws on the side of the desktop using a Phillips #0 or a flathead screwdriver.
    • These screws hold the GPU in place. Do not misplace them.
  8. GPU Replacement: Schritt 8, Bild 1 von 2 GPU Replacement: Schritt 8, Bild 2 von 2
    • Gently press down on the right side of the PCI-E tab until there is a click.
    • The click signifies the GPU has been released.
  9. GPU Replacement: Schritt 9, Bild 1 von 1
    • Gently pull the GPU out of the PCI-E slot.
  10. GPU Replacement: Schritt 10, Bild 1 von 3 GPU Replacement: Schritt 10, Bild 2 von 3 GPU Replacement: Schritt 10, Bild 3 von 3
    • Line up the pins of the new GPU with the empty PCI-E slot.
    • Gently push the new GPU into the PCI-E slot until the tab clicks.
  11. GPU Replacement: Schritt 11, Bild 1 von 3 GPU Replacement: Schritt 11, Bild 2 von 3 GPU Replacement: Schritt 11, Bild 3 von 3
    • Gently connect the 8-pin PCI-E cable from the power supply to the new GPU.
  12. GPU Replacement: Schritt 12, Bild 1 von 2 GPU Replacement: Schritt 12, Bild 2 von 2
    • Screw the UTS 6-32 screws which hold the GPU in place back in using a Phillips #0 screwdriver.
  13. GPU Replacement: Schritt 13, Bild 1 von 1
    • Gently place the side panel back on the case.
  14. GPU Replacement: Schritt 14, Bild 1 von 3 GPU Replacement: Schritt 14, Bild 2 von 3 GPU Replacement: Schritt 14, Bild 3 von 3
    • Screw in the side panel screws.
  15. GPU Replacement: Schritt 15, Bild 1 von 3 GPU Replacement: Schritt 15, Bild 2 von 3 GPU Replacement: Schritt 15, Bild 3 von 3
    • Plug the desktop back into a power source.
    • Turn the desktop's power supply on.
    • If the fans on the bottom of the GPU are not spinning once the desktop is on, retry this process. Or begin troubleshooting for a defective GPU.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Mason Price
295 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-16, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 2-16, Briggs Fall 2022
CSULA-BRIGGS-F22S2G16
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 28
Letzte 30 Tage: 141
Insgesamt: 1,757
