Zum Hauptinhalt wechseln
GT Aggressor Pro Mountain Front Wheel Spoke Replacement
Was du brauchst
  1. GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: Schritt 1, Bild 1 von 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: Schritt 1, Bild 2 von 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: Schritt 1, Bild 3 von 3
    • Placing your bike on a stand or having a friend hold the bike will make the repair easier to perform.
    • Pull the quick-release lever on the front wheel of the bike and turn it to loosen it.
  2. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 2, Bild 1 von 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 2, Bild 2 von 2
    • Remove the quick-release lever.
  3. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 3, Bild 1 von 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 3, Bild 2 von 2
    • Remove the fork from the axle of the wheel.
  4. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 4, Bild 1 von 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 4, Bild 2 von 2
    • Remove the cap from the Presta air valve that is located between the spokes on the rim.
  5. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 5, Bild 1 von 1
    • Push up on the Presta valve to release the air in the inner tube.
  6. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 6, Bild 1 von 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 6, Bild 2 von 2
    • Twist the valve to remove the nut from it.
  7. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 7, Bild 1 von 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 7, Bild 2 von 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 7, Bild 3 von 3
    • Remove the tire and inner tube from the rim.
    • It is possible to do this with your hands but using a tire lever would simplify the process.
  8. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 8, Bild 1 von 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 8, Bild 2 von 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 8, Bild 3 von 3
    • Loosen the spoke by using the spoke wrench.
    • Use a flat head screwdriver to remove the screw corresponding to the damaged or broken spoke.
  9. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 9, Bild 1 von 1
    • Use a T25 screwdriver to remove the six 10.0 mm screws from the disk brake rotor.
  10. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 10, Bild 1 von 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 10, Bild 2 von 2
    • Unthread and remove the spoke from the rim and the hub.
    • Make sure to look at the alignment of the spoke removed in order to put the new spoke back on the same way.
    • The spoke will come out of the hole.
  11. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: Schritt 11, Bild 1 von 1
    • Thread the new spoke into the rim.
    • Make sure the alignment/placement of the new spoke is the same as the old one.
Abschluss
Thank you for using our guide. Enjoy getting back on the trails or roads!
Ronaldo Pascual
193 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 58
Insgesamt: 912
