Zum Hauptinhalt wechseln
Replace Gaggenau HLED22 temperature and humidity switch
Was du brauchst
  1. Replace Gaggenau HLED22 temperature and humidity switch, Temperature and humidity switch: Schritt 1, Bild 1 von 2 Replace Gaggenau HLED22 temperature and humidity switch, Temperature and humidity switch: Schritt 1, Bild 2 von 2
    • Remove the Philips screw holding the steam oven to the cabinet.
    • The removal of the screw requires a Philips PH2 screwdriver
  2. Replace Gaggenau HLED22 temperature and humidity switch: Schritt 2, Bild 1 von 2 Replace Gaggenau HLED22 temperature and humidity switch: Schritt 2, Bild 2 von 2
    • Pull the oven out of the cabinet by about 10-15cm (4" to 6" inches). Secure the door with some tape to the top of the oven.
    • This is important so as to prevent the door from falling out when removing the panel!
  3. Replace Gaggenau HLED22 temperature and humidity switch: Schritt 3, Bild 1 von 3 Replace Gaggenau HLED22 temperature and humidity switch: Schritt 3, Bild 2 von 3 Replace Gaggenau HLED22 temperature and humidity switch: Schritt 3, Bild 3 von 3
    • The front control panel is held in place with 4 screws (TR20) on the back of the panel. Those can sometimes be tight. (Sorry, no pictures available). The screws can either be felt or seen, depending on how far the oven was pulled out of the cabinet.
    • After removing the screws, hold the panel so that the 2 ribbon cables to the control unit do not break.
    • Remove the wide cable where it connects to the oven and the thin cable at the control panel.
    • On the door side is still a fixation, which can easily fall out! Check the last picture (blue circle)
  4. Replace Gaggenau HLED22 temperature and humidity switch: Schritt 4, Bild 1 von 2 Replace Gaggenau HLED22 temperature and humidity switch: Schritt 4, Bild 2 von 2
    • Disconnect the ribbon cable from the switch to the display. Remove the 5 screws holding the switch to the panel. Remove the switch.
    • A cleaning is worthwhile afterwards!
Abschluss
Repeat the steps in reverse order to reassemble your device.
de en
100%
Hier starten ›
Johannes
421 Reputation
3 Anleitungen geschrieben
Repair Café Malmö Mitglied von Repair Café Malmö
Community
4 Mitglieder
6 Anleitungen geschrieben
7 Kommentare
Fragen: Schritt 3 : “Die Verblendung wird mit 4 Schrauben (TR20) auf der Rückseite der Verbledung gehalten. Kann etwas fest sitzen.”
Ist hier gemeint - 4 Schrauben der Blende oben und unten? Vielleicht ein Foto?
“Auf der Türseite ist noch eine Fixierung, die kann leicht rausfallen!” Was ist mit Fixierung gemeint? Wo sitzt die Fixierung und wofür ist sie erforderlich?
Udo Schürmann - Antwort
Hallo Udo,
danke für deinen Kommentar. Ich gehe mal auf die Punkte ein:
Schritt 3: leider sind die 4 Schrauben auf der Rückseite der Verblendung und in meinem Fall war der Dampfgarer schon bzw. noch eingebaut, weshalb es mir nicht möglich war ein Foto davon zu machen, die Kamera passt einfach nicht dazwischen. Ich weiß auch, dass die Bildqualität etwas zu wünschen lässt, aber man kann beim Bild auf den beiden Außenseiten der Verblendung 4 Löcher sehen, die werden jeweils von der Rückseite gehalten. Auf dem letzten Foto von Schritt 4 kann man es auch sehen. Man sieht die Schrauben auch sofort wenn man das Gerät etwas herauszieht.
Bzgl. der Fixierung der Tür: Das ist ein kleines Metallstück das lose in der ausgefrästen Mulde liegt und entsprechend leicht rausfallen kann. Sieht man ebenfalls auf Bild 4.2, dort liegt es unterhalb der Mulde. Ich werde das nochmal markieren.
Danke für die Hinweise, ich hoffe, die Reparatur ging trotzdem gut?
Johannes - Antwort
Johannes,
erst einmal vielen Dank für die Tips.
Habe aber im Moment das Problem die Außenblende/ Alu ab zu bekommen. Sitzt die wirklich so fest ?( Gerät ist eingebaut)
Habe vier Schrauben gelöst , von oben zwei ,von unten zwei.
Oder bin ich auf dem falschen Weg ?
Johannes,
habe das Problem gelöst! Bei mir waren bei den vier Schrauben, Kunststoffabdeckung darüber. Somit nicht sofort erkannt.
Aber jetzt bin ich auf einem guten Weg.
Danke
Udo
Johannes,
Nochmal Dank für die Anleitung !
Kann man den “Schalter Bedienteil rechts, Nr.: 00174722”, irgendwo preiswerter beziehen als bei Gaggenau? ( ca. 182,40 € )
Gruß
Danke, Udo
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 20
Letzte 30 Tage: 41
Insgesamt: 2,369
