Einleitung
This guide will give step by step instructions on how to remove and replace the camera in a Samsung Galaxy Tab S 10.5.
Was du brauchst
Place the plastic opening tool into the SD card slot or charge port.
Try in an upward motion until you see a separation between the tablet and back cover.
Work around the entire device by sliding the plastic opening tool around the rim.
Use a spudger to disconnect the camera from the motherboard and then remove the camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
