Einleitung
How to remove the back panel from a Game Boy Advance.
Was du brauchst
Einführungsvideo
Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
Remove the six back panel screws using a Tri-wing Screwdriver.
Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
Remove the back panel by pulling away with one hand and the front secured in the other hand.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
