Zum Hauptinhalt wechseln
Game Boy Advance Buttons and LCD Screen Replacement
Was du brauchst
  1. Game Boy Advance Buttons and LCD Screen Replacement, Remove the Battery Cover/Batteries: Schritt 1, Bild 1 von 3 Game Boy Advance Buttons and LCD Screen Replacement, Remove the Battery Cover/Batteries: Schritt 1, Bild 2 von 3 Game Boy Advance Buttons and LCD Screen Replacement, Remove the Battery Cover/Batteries: Schritt 1, Bild 3 von 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Buttons and LCD Screen Replacement, Unscrew the Back Panel: Schritt 2, Bild 1 von 2 Game Boy Advance Buttons and LCD Screen Replacement, Unscrew the Back Panel: Schritt 2, Bild 2 von 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Buttons and LCD Screen Replacement, Remove the Back Panel: Schritt 3, Bild 1 von 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Buttons and LCD Screen Replacement, Remove Triggers: Schritt 4, Bild 1 von 2 Game Boy Advance Buttons and LCD Screen Replacement, Remove Triggers: Schritt 4, Bild 2 von 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  5. Game Boy Advance Buttons and LCD Screen Replacement, Remove the On/Off Switch: Schritt 5, Bild 1 von 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance Buttons and LCD Screen Replacement, Buttons and LCD Screen: Schritt 6, Bild 1 von 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  7. Game Boy Advance Buttons and LCD Screen Replacement: Schritt 7, Bild 1 von 2 Game Boy Advance Buttons and LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Aldo Corona
799 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 16-29, Maness Winter 2010 Mitglied von Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Mitglieder
61 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 65
Insgesamt: 7,650
