Zum Hauptinhalt wechseln
Einleitung
Use this repair guide to replace the screen if it has been damaged.
Ersatzteile
Keine Ersatzteile angegeben.
Einführungsvideo
  1. Remove the back battery cover by pinching down on the tab and pulling outward. Remove the back battery cover by pinching down on the tab and pulling outward. Remove the back battery cover by pinching down on the tab and pulling outward.
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Remove the six back panel screws using a Y1 screw driver.
    • Remove the six back panel screws using a Y1 screw driver.
  3. Remove bottom back panel screw with a Phillips #1 screw driver.
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Remove left and right triggers by lifting and pulling them away from the system. Do the same for side panels.
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary. Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
  8. Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected. Beware not to damage the top ribbon by pulling up gently.
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Remove the rubber button pads from their pockets. Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand. Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB). Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers. Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  11. Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad. The screen and the front panel is connected by a black tape that could rip if not removed carefully. You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  12. Use the tweezers to remove the black tape if needed.
    • Use the tweezers to remove the black tape if needed.
Ziellinie
14 weitere Nutzer haben diese Anleitung absolviert.
Adam
775 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 16-29, Maness Winter 2010 Mitglied von Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Mitglieder
51 Anleitungen geschrieben
5 Kommentare
Doesn't say where you can get new screen !!!!??
andrew Davies - Antwort
Doesn't say where to get screen from !!!??
Do this with the Game Boy Advance SP please!
Santi12008 - Antwort
It does not say where you can get a new screen
criscaanca - Antwort
DONT DO THIS LIKE THAT!!!. The area of the screen in the space beside the D-pad is the only area where the LCD glass is completely exposed. It’s Literaly the WORST place to apply pressure, 99% chances for the LCD to break. There is a notch on the top right corner and another under the ribbon cable. Making your way from the top right to the left is far more safe.
Flyingmcintosh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 28
Letzten 7 Tage: 129
Letzten 30 Tage: 636
Insgesamt: 26,456
