Zum Hauptinhalt wechseln
Game Boy Batteries Replacement
Was du brauchst
  1. Game Boy Batteries Replacement, Batteries: Schritt 1, Bild 1 von 2 Game Boy Batteries Replacement, Batteries: Schritt 1, Bild 2 von 2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Batteries Replacement: Schritt 2, Bild 1 von 3 Game Boy Batteries Replacement: Schritt 2, Bild 2 von 3 Game Boy Batteries Replacement: Schritt 2, Bild 3 von 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Batteries Replacement: Schritt 3, Bild 1 von 2 Game Boy Batteries Replacement: Schritt 3, Bild 2 von 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
Abschluss
25 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 3-2, Johann Summer 2010 Mitglied von Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 Mitglieder
34 Anleitungen geschrieben
4 Kommentare
This was a very helpful guide. I had no idea how to replace the batteries for my GameBoy, but thanks to this amazing and helpful guide, I was able to do so. The only issue that I have with this guide is that it did not explain how to properly dispose the used batteries. I ended up soaking them in gasoline and lighting them on fire because the colors look super pretty. Don’t breath the smoke though! I’m pretty sure the smoke is toxic?
Mentat - Antwort
I have struggled with this for 20 years. Thank you.
Igor Kolosha - Antwort
My problem was that I removed four batteries from my Game Boy Classic but only inserted three new ones. It didn’t work. An expert told me to also insert four new ones, it worked.
Akula - Antwort
Awesome! I finally know how!
Ethan Sligar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 65
Letzte 30 Tage: 243
Insgesamt: 21,099
