Einleitung
The LCD Display is the screen that displays images from the Game Boy Color. This guide details how to disassemble and install an LCD Display.
Was du brauchst
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
Push up on the tabs on either side of the ribbon with a spudger.
Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
38 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Horrible instructions, TBH.
Broke the plastic around the screen and doesn't turn on anymore -_- . Guess now I can put a backlit in but not how I wanted it to go
Same thing happened to me, but its not really an issue. The way I see it, this is an article for replacing the screen, so it doesnt much matter if the one you’re taking out is broken.
