Zum Hauptinhalt wechseln
Game Boy Color Motherboard Replacement
Was du brauchst
  1. Game Boy Color Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Game Boy Color Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Motherboard Replacement, Back Housing: Schritt 3, Bild 1 von 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Motherboard Replacement: Schritt 4, Bild 1 von 2 Game Boy Color Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Motherboard Replacement, LCD Ribbon Cable: Schritt 5, Bild 1 von 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 Game Boy Color Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Gently lift the motherboard from the front housing.
Abschluss
19 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Wu
1.446 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 19-47, Regan Winter 2013 Mitglied von Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Mitglieder
56 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 49
Letzte 30 Tage: 221
Insgesamt: 17,192
