Zum Hauptinhalt wechseln
Game Boy Color Screen Cover Replacement
Was du brauchst
  1. Game Boy Color Screen Cover Replacement, Battery: Schritt 1, Bild 1 von 2 Game Boy Color Screen Cover Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Screen Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Screen Cover Replacement, Screen Cover: Schritt 3, Bild 1 von 1
    • Carefully slide a razor blade under one of the corners of the screen cover.
  4. Game Boy Color Screen Cover Replacement: Schritt 4, Bild 1 von 1
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
Abschluss
24 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 19-47, Regan Winter 2013 Mitglied von Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Mitglieder
56 Anleitungen geschrieben
4 Kommentare
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Antwort
You only need step 7 and 8.
h027299c - Antwort
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Antwort
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 34
Letzte 30 Tage: 190
Insgesamt: 22,024
