Einleitung
The speakers on the device may become dirty or damaged by dust and dirt, requiring a cleaning or replacement. This guide will show you how to do both.
Was du brauchst
Press up on the battery holder tab on the back to lift it up and remove it
Using a Y1 screwdriver, remove the six screws on the back of the device.
Remove the 3 PH0 Phillips screws near the bottom of the device.
Push up on the two dark grey pieces of plastic on the display ribbon cable bracket.
Make sure they are in a position similar to the one in the second image. Then they are fully extended.
Using a spudger, screwdriver or other long thin object, gently pull the ribbon cable out of the bracket.
If the speaker is simply dirty, clean it and the speaker holes in the case. Then, reassemble it and test the speakers. If they still don't work then continue on.
Once you've removed the motherboard, you are now free to desolder the speaker wires and replace it with a new one.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
