Zum Hauptinhalt wechseln
Game Boy Pocket Motherboard Replacement
Was du brauchst
  1. Game Boy Pocket Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Game Boy Pocket Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Game Boy Pocket Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Motherboard Replacement: Schritt 2, Bild 1 von 3 Game Boy Pocket Motherboard Replacement: Schritt 2, Bild 2 von 3 Game Boy Pocket Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket Motherboard Replacement: Schritt 4, Bild 1 von 3 Game Boy Pocket Motherboard Replacement: Schritt 4, Bild 2 von 3 Game Boy Pocket Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Motherboard Replacement: Schritt 5, Bild 1 von 2 Game Boy Pocket Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Motherboard Replacement: Schritt 6, Bild 1 von 2 Game Boy Pocket Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Adriana Rahrig
1.622 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-1, Leahy Fall 2014 Mitglied von USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 91
Insgesamt: 6,000
