Einleitung
Follow this guide if you need to replace the triggers and bumpers in your GameSir Cyclone 2 controller.
Was du brauchst
Flip the controller around so the back part is facing you.
Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
Face the controller towards you and lift up the front plate. It should pop out with minimal force.
once the face plate is off locate the top bumpers
Use a Phillips #00 driver to remove two screws on either side of the power button.
Remove the assembly that includes the power button and the top bumper buttons.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
5 Kommentare zur Anleitung
Onde eu consigo os botões r2/l2?
I would like to know if someone fixed this buttons, the cover of my L2 button popped of, the one attached to the motherboard, and i think i'm let a small blue piece escape, if someone fixed this before and could give a hint it would be nice
Does anybody know where i can get these replacement parts? Gamesir doesn’t sell replacement parts
I guess ali express would be a good place to find this https://share.google/h6P62vcuD7WNVSHLR
More information could be found in the gamesir discord channel -> https://discord.com/channels/10089102875...
