Einleitung
Follow this guide if you need to replace the joystick covers of your GameSir Cyclone 2 controller.
Was du brauchst
Flip the controller around so the back part is facing you.
Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
Face the controller towards you and lift up the front plate. It should pop out with minimal force.
Pull both joystick covers straight up to remove them from the controller.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
