Zum Hauptinhalt wechseln
GameSir Cyclone 2 Rumble Motors Replacement
Was du brauchst
  1. GameSir Cyclone 2 Rumble Motors Replacement, Face Plate: Schritt 1, Bild 1 von 3 GameSir Cyclone 2 Rumble Motors Replacement, Face Plate: Schritt 1, Bild 2 von 3 GameSir Cyclone 2 Rumble Motors Replacement, Face Plate: Schritt 1, Bild 3 von 3
    • Flip the controller around so the back part is facing you.
    • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
    • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
    Frag FixBot
  2. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 2, Bild 1 von 1
    • The two larger screws belong on the top two sockets of the controller
    Frag FixBot
  3. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 3, Bild 1 von 1
    • The remaining five sockets are located below, two on each side, and one in the center.
    Frag FixBot
  4. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 4, Bild 1 von 2 GameSir Cyclone 2 Rumble Motors Replacement: Schritt 4, Bild 2 von 2
    • Face the controller towards you and lift up the front plate. It should pop out with minimal force.
    • The d-pad and action buttons will come loose, as well.
    Frag FixBot
  5. GameSir Cyclone 2 Rumble Motors Replacement, Joystick Covers: Schritt 5, Bild 1 von 3 GameSir Cyclone 2 Rumble Motors Replacement, Joystick Covers: Schritt 5, Bild 2 von 3 GameSir Cyclone 2 Rumble Motors Replacement, Joystick Covers: Schritt 5, Bild 3 von 3
    • Pull both joystick covers straight up to remove them from the controller.
    Frag FixBot
  6. GameSir Cyclone 2 Rumble Motors Replacement, Left and Right Bumpers and Triggers: Schritt 6, Bild 1 von 1
    • once the face plate is off locate the top bumpers
    Frag FixBot
  7. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #00 driver to remove two screws on either side of the power button.
    • Remove the assembly that includes the power button and the top bumper buttons.
    Frag FixBot
  8. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 8, Bild 1 von 1
    • remove the bumpers and replace with the new set you have aquired
    Frag FixBot
  9. GameSir Cyclone 2 Rumble Motors Replacement, LED: Schritt 9, Bild 1 von 1
    • Locate the two black boxes towards the bottom of the controller.
    • Remove these two boxes by pulling them away from the controller. They should snap right off.
    Frag FixBot
  10. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 10, Bild 1 von 1
    • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED under the black boxes you removed in the previous step.
    • Lift the upper ends of each LED diffuser and remove them.
    Frag FixBot
  11. GameSir Cyclone 2 Rumble Motors Replacement, Battery: Schritt 11, Bild 1 von 1
    • Locate and remove the four screws that hold down the LED diffuser tracks.
    • Remove the LED diffuser tracks.
    Frag FixBot
  12. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 12, Bild 1 von 1
    • Remove the center screw to remove the motherboard
    Frag FixBot
  13. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 13, Bild 1 von 2 GameSir Cyclone 2 Rumble Motors Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the battery connector from the socket on the motherboard.
    • Remove the battery.
    Frag FixBot
  14. GameSir Cyclone 2 Rumble Motors Replacement, Rumble Motors: Schritt 14, Bild 1 von 2 GameSir Cyclone 2 Rumble Motors Replacement, Rumble Motors: Schritt 14, Bild 2 von 2
    • The motors are connected to the mother board on the bottom left and right.
    • They have a simple plug in and out system, just pull with little force trying to stay stright to not damage outlet
    Frag FixBot
  15. GameSir Cyclone 2 Rumble Motors Replacement: Schritt 15, Bild 1 von 2 GameSir Cyclone 2 Rumble Motors Replacement: Schritt 15, Bild 2 von 2
    • Once dissconnected just switch out with new ones
    • Notice the size difference between the two motors the larger on will be for the left side of the contoller to keep the contoller balanced
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Mitglied von UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 145
