Zum Hauptinhalt wechseln
GameSir G8 Galileo Motherboard Replacement
Was du brauchst
  1. GameSir G8 Galileo Motherboard Replacement, motherboard: Schritt 1, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement, motherboard: Schritt 1, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement, motherboard: Schritt 1, Bild 3 von 3
    • Use a hair dryer or heat gun on the low setting to gently warm the center grip pad to soften the adhesive underneath.
    • Place the nozzle 2–3 inches above the device and keep moving it in small circles until the surface is warm and the adhesive has loosened.
    • Don't leave the nozzle in one place for two long or you risk damage to the controller.
    Frag FixBot
  2. GameSir G8 Galileo Motherboard Replacement: Schritt 2, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 2, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool into the edge of the center grip pad.
    • Once the edge is free, use your fingers to peel off the grip pad.
    Frag FixBot
  3. GameSir G8 Galileo Motherboard Replacement: Schritt 3, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 3, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the three screws from the center front panel.
    Frag FixBot
  4. GameSir G8 Galileo Motherboard Replacement: Schritt 4, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 4, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the plastic cover from both sides of the controller with your hand.
    • They’re held in place by magnets and should pop off easily.
    Frag FixBot
  5. GameSir G8 Galileo Motherboard Replacement: Schritt 5, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 5, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the two Phillips #0 screws from the right side.
    Frag FixBot
  6. GameSir G8 Galileo Motherboard Replacement: Schritt 6, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 6, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Turn the controller around and remove the rear housing.
    • The rear housing covers only the back of the center section and the right grip. The back cover of the left grip remains attached to the controller.
    Frag FixBot
  7. GameSir G8 Galileo Motherboard Replacement: Schritt 7, Bild 1 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 7, Bild 2 von 3 GameSir G8 Galileo Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove nine screws from the motherboard using a Phillips #0 screwdriver.
    • Squeeze the edges of the connector and pull it gently from its socket on the board.
    • Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable from its socket.
    Frag FixBot
  8. GameSir G8 Galileo Motherboard Replacement: Schritt 8, Bild 1 von 2 GameSir G8 Galileo Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the motherboard.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-2, Bowman Fall 2025 Mitglied von UMass Dartmouth, Team 2-2, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 68
Insgesamt: 286
