Einleitung
If your right Joy-stick is damaged, this guide will help you access the joy-stick and the joy-stick board.
This guide requires a heat gun or hair dryer. For tips on using a heat gun safely and avoiding damage to your device, see this How to Use a Heat Gun to Soften Adhesive or the How to Use a Hair Dryer to Soften Adhesive guide.
Before you begin, power off the device and disconnect it from the charger.
Was du brauchst
Use a hair dryer or heat gun on the low setting to gently warm the center grip pad to soften the adhesive underneath.
Place the nozzle 2–3 inches above the device and keep moving it in small circles until the surface is warm and the adhesive has loosened.
Insert the plastic opening tool into the edge of the center grip pad.
Once the edge is free, use your fingers to peel off the grip pad.
Use a Phillips #0 screwdriver to remove the three screws from the center front panel.
Remove nine screws from the motherboard using a Phillips #0 screwdriver.
Squeeze the edges of the connector and pull it gently from its socket on the board.
Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
Use tweezers or your fingers to gently pull the cable from its socket.
Pull the joystick cover off the joystick module and through the top cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
