Zum Hauptinhalt wechseln
GameSir K1 Kaleid Controller Motherboard Replacement
Was du brauchst
  1. GameSir K1 Kaleid Controller Motherboard Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Remove seven 1 mm screws from the backside of the controller using a TR6 Torx screwdriver.
    • There may be a screw covered under the manufacturer's sticker.
    Frag FixBot
    Kommentar hinzufügen
  2. GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 2, Bild 1 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 2, Bild 2 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Hold the controller between your hands, with the front panel facing down.
    • Lift the back panel.
    • It should come up easily. If met with resistance, check for a missed screw on the back panel.
    Frag FixBot
  3. GameSir K1 Kaleid Controller Motherboard Replacement, Bumpers: Schritt 3, Bild 1 von 3 GameSir K1 Kaleid Controller Motherboard Replacement, Bumpers: Schritt 3, Bild 2 von 3 GameSir K1 Kaleid Controller Motherboard Replacement, Bumpers: Schritt 3, Bild 3 von 3
    • Hold the controller, grasp the rubber joystick cover, and pull upwards.
    • There will be resistance; pull firmly.
    • Repeat for the second joystick cover.
    Frag FixBot
  4. GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove two 1 mm screws on either side of the power button using a TR6 Torx screwdriver.
    Frag FixBot
  5. GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 5, Bild 1 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 5, Bild 2 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the power button and bumpers.
    Frag FixBot
  6. GameSir K1 Kaleid Controller Motherboard Replacement, D-Pad: Schritt 6, Bild 1 von 1
    • Remove the four 1 mm screws on the daughterboard using a TR6 Torx screwdriver.
    • The screws are located above and below the D-pad and then to the left and to the southeast of the X, Y, A, B pad.
    Frag FixBot
  7. GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 7, Bild 1 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 7, Bild 2 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Gently pull the daughterboard up from the front center and open it like a hinge to the left exposing the ribbon.
    • Use the iFixit opening tool or tweezers to lift the black clamp holding the ribbon in. Align the iFixit opening tool with the ribbon, gently push under the clamp, and then pop it upwards.
    • The ribbon can be removed from either the daughterboard or the motherboard below.
    • Replace this daughterboard to fix the D-pad function.
    Frag FixBot
  8. GameSir K1 Kaleid Controller Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 GameSir K1 Kaleid Controller Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 GameSir K1 Kaleid Controller Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Using your fingers, gently grab the top of one of the silicone LED strips and begin to remove it from the plastic holders to expose the screws below.
    • The LED strip can gently be removed along with the black end coverings located at the bottom.
    • Use the spudger or fingers to gently pry off the end coverings.
    Frag FixBot
  9. GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove five screws, which will release the clear runners. Set both the screws and runners aside.
    Frag FixBot
  10. GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 10, Bild 1 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 10, Bild 2 von 3 GameSir K1 Kaleid Controller Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Insert the opening tool through the center, between the motherboard and shell, and lift. This will raise the motherboard off the pegs.
    • The motherboard will get stuck on the pegs unless lifted out levelly from the shell.
    • Once the board is raised above the edge of the controller shell, use your fingers to pull the rest of the way.
    • Replace the motherboard to get the joysticks working again.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 78
Insgesamt: 835
