Einleitung
If you need to disassemble your GameSir K1 Kaleid controller, use this guide to access the interior of the controller.
Was du brauchst
Remove seven 1 mm screws from the backside of the controller using a TR6 Torx screwdriver.
Hold the controller between your hands, with the front panel facing down.
Lift the back panel.
Eine weitere Person hat diese Anleitung absolviert.
