Zum Hauptinhalt wechseln
GameSir Nova 2 Lite Bumper Replacement
Was du brauchst
  1. GameSir Nova 2 Lite Bumper Replacement, Battery: Schritt 1, Bild 1 von 2 GameSir Nova 2 Lite Bumper Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you take your controller apart make sure it is powered off by holding the power button down for 15 seconds until it stops blinking.
    • Use a Phillips #0 screwdriver to remove the four 8.5 mm screws from the bottom of the controller's casing.
    Frag FixBot
  2. GameSir Nova 2 Lite Bumper Replacement: Schritt 2, Bild 1 von 3 GameSir Nova 2 Lite Bumper Replacement: Schritt 2, Bild 2 von 3 GameSir Nova 2 Lite Bumper Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening tool between the two halves to open the controller's casing.
    • You will feel several internal latches called “snap-fit connectors.”
    • Disconnect them by sliding the opening tool along the seam in the casing, applying continuous pressure.
    • Once you find a connector, apply increased pressure until you hear a snapping sound.
    • Repeat this process until all of the connectors are disconnected.
    • Separate the top and bottom of the controller case.
    Frag FixBot
  3. GameSir Nova 2 Lite Bumper Replacement: Schritt 3, Bild 1 von 2 GameSir Nova 2 Lite Bumper Replacement: Schritt 3, Bild 2 von 2
    • Set aside the bottom half of the shell.
    • Position the controller so that the motherboard is visible.
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    Frag FixBot
  4. GameSir Nova 2 Lite Bumper Replacement: Schritt 4, Bild 1 von 2 GameSir Nova 2 Lite Bumper Replacement: Schritt 4, Bild 2 von 2
    • If the battery appears swollen follow this link.
    • The battery is held in place by double-sided adhesive.
    • Use a spudger to loosen the tape securing the battery.
    • Remove the battery from the controller.
    Frag FixBot
  5. GameSir Nova 2 Lite Bumper Replacement, Rumble Motor: Schritt 5, Bild 1 von 2 GameSir Nova 2 Lite Bumper Replacement, Rumble Motor: Schritt 5, Bild 2 von 2
    • Push on alternating sides of the JST connector to release it from the socket on the circuit board.
    Frag FixBot
  6. GameSir Nova 2 Lite Bumper Replacement: Schritt 6, Bild 1 von 1
    • Pull the motor out of its socket.
    • Repeat the steps for the other rumble motor.
    Frag FixBot
  7. GameSir Nova 2 Lite Bumper Replacement, Bumper: Schritt 7, Bild 1 von 3 GameSir Nova 2 Lite Bumper Replacement, Bumper: Schritt 7, Bild 2 von 3 GameSir Nova 2 Lite Bumper Replacement, Bumper: Schritt 7, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws from the main board.
    • Remove the motherboard and frame from the outer case.
    Frag FixBot
  8. GameSir Nova 2 Lite Bumper Replacement: Schritt 8, Bild 1 von 3 GameSir Nova 2 Lite Bumper Replacement: Schritt 8, Bild 2 von 3 GameSir Nova 2 Lite Bumper Replacement: Schritt 8, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove two 5.5 mm screws from the casing.
    • Use an opening tool to separate the motherboard from the casing.
    Frag FixBot
  9. GameSir Nova 2 Lite Bumper Replacement: Schritt 9, Bild 1 von 3 GameSir Nova 2 Lite Bumper Replacement: Schritt 9, Bild 2 von 3 GameSir Nova 2 Lite Bumper Replacement: Schritt 9, Bild 3 von 3
    • With the top of the bumpers facing down, gently pull each from the case.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 82
Insgesamt: 504
